Re: Changing the DLR / sidelight to LED
bloodlegna said:
I am curious, can you use white LEDs to replace the rear brake lights ?
Furthermore is it easy to access the rear lights ?
yes you could but it would look pink in comparison to a red led, both autobulbs and hids4 u stipulate this on their websites.(RED gives a more intense light,your high level brake light is made up of red leds your rear indicators are made up of yellow leds) the rear lights are a doddle to do.
1.open boot remove the the access cards left&right of boot walls.IGNITION OFF :thumbup:
2.remove plastic fixing bolts turning anti clockwise (bit tight).
3.gently lift rear light cluster out of the car there is a stud at the top so just be gentle turn the cluster over toward you to gain access to bulb holder(you dont need to disconnect the cable leading to the light(thats awkward)
4 turn bulb holder anti clockwise take out bulb and replace with new easy.
5.replace clusters, bolt up fixings replace boot cards and bobs your uncle
i know changing rear bulbs is a bit anal i love led lighting for its intensity look :thumbup:
but fittings these red 380/92smd bulbs just makes the rear lights look that more expensive and classier like top of the line audis look,and they are a lot richer and brighter looking
