SmartMW
Kraków, PL
No code is necessary :)
Thank you :) I will try to manage it on Wednesday, so I will share my thoughts about updating process.
Could you kindly check if the list I have is complete?
  • Pendrive: 64 GB
  • Firmware update: NG4-N42c.zip
  • Maps update: NG4_Maps_2022.0.zip
  • Risk areas: NG4_NaviDrive3D_WipCom3D_2022-06-14_SCDB.zip
Is there anything more I need or I should proceed successfully with all of those?
NF7
Slovenia
If possible, I would use a 32GB USB Drive. I had some issues where NG4 did not recognize my 64GB and higher drives.
Otherwise, you have everything ready. Just keep in mind, that you need to keep only one thing on the drive at any time.
But this order of installation (FW -> Maps -> Risk Areas) is correct.
SmartMW
Kraków, PL
Everything worked like a charm. I have prepared three different pendrives (16 GB, 32 GB, 8 GB all USB2.0), so I did not have to wait to format the same one after each update. I had just one 0x26 error during map update but replacing pendrive worked fine according to instruction. Now I have installed the newest firmware, 2022 maps amd 2022/06 risk areas. Thank you :)
PS. It was all done in Citroen C5 X7 with NG4 radio.
  • Like
Reactions: NF7
NF7
Slovenia
Perfect. Glad to see that. That error is normal and does not influence the installation of Maps. Just follow the instructions and you're set for success :D
Zardos
united Kindom
Forgive me if I’m being a bit thick, again! 🤣🤣 does this latest link include POI as they weren’t included in the one I downloaded before, if not can they be added from previous versions? I’ve found my 2015 installation discs but I couldn’t see any specific folder called POI,
NF7
Slovenia
Yes. 2022 maps include POI (from original PSA 2016 maps). Just keep in mind, they are only icons on the map, you cannot search for specific POI within the navigation interface.
Andyrcz
Farnborough
Hi I have a 2011 rcz 200.
what’s map upgrade Can I upgrade to. 2016 or the 2021 .
I have ng4 sat nav.
Is there a free link to the 2016 maps.
Thanks.
. The previous guide is a little bit old so I decided to update it with the latest possible FW, latest maps, and updated risk areas.
LATEST FIRMWARE: N42c (final update - SatNav support discontinued after 2016).
LATEST MAPS: EUROPE 2022-0 (For Eastern Europe (maps 2020-2) use this
LINK)
LATEST RISK AREAS/RADARS: EU RADARS 2022.06.14 (June Update)
All files are available in their respective parts of the guide.
UPDATING THE FIRMWARE
1. Check your installed firmware version via SETUP -> Settings -> Version Information
2. If you see N42c anywhere in the presented firmware version you already have the latest firmware and you do not need to update it. You can move to the MAP updating part of the guide. If you do not have the latest version, proceed to step 3.
3. Download this file: LINK
4. Prepare USB 32GB or SD CARD formatted as FAT32, 64KB Cluster size.
IT IS IMPORTANT THAT YOU FORMAT VIA WINDOWS AND DO NOT USE QUICK FORMAT. The regular format will take more time, but it is absolutely necessary.
5. Extract the downloaded file and put all files into the ROOT of the USB/SD CARD. Enable in Windows to view "hidden files" and check if any file other than that of the firmware generated in the root of the USB / SD CARD. If you see any "rogue" files, delete them.
6. Turn on the car. Keep it running and insert the USB or SD CARD into their locations (SD CARD in front of the Console, USB under the armrest).
7. If you followed the guide the NG4 system will automatically detect and prompt you to start the update. Click yes on the console and wait for it to finish.
KEEP THE CAR RUNNING UNTIL IN FINISHES WITH THE UPDATE. You do not want the car to turn off and cancel the update. It could destroy your system.
8. When the NG4 resets check the firmware version again. If you see N42c the update was successful.
UPDATING THE MAPS
1. Download this file: LINK (2022-0 with original 2016 POI from PSA).
2. Prepare USB 32GB or SD CARD formatted as FAT32, 64KB Cluster size.
3. Extract all files from the ZIP file to the ROOT of the USB / SD CARD. Enable in Windows to view "hidden files" and check if any file other than that of the map files included in the ZIP file generated in the root of the USB / SD CARD. If you see any "rogue" files, delete them.
This is how your USB / SD Stick should look like after copying the files (everything should be the same, except the last file which is from the 2020 maps):
4. Turn on the car. Keep it running and insert the USB or SD CARD into their locations (SD CARD in front of the Console, USB under the armrest).
5. If you did everything correctly, the NG4 will recognize the new maps automatically and prompt you to start the update. It takes around 40-50 minutes. It is advised to drive around with the car in the meantime.
KEEP THE CAR RUNNING UNTIL IT FINISHES WITH THE UPDATE. You do not want the car to turn off and cancel the update. It could destroy your system.
5.1. If during the update the error 0x26E appears, just press "OK" and wait for the system to restart (leave the key or SD card connected) and it will continue the update.
6. When it finishes, it will prompt you to press OK and remove the USB/SD CARD. Remove it and ONLY THEN press OK. After the NG4 System resets check the map version via SETUP -> When in the setup menu LONG PRESS SETUP -> GPS Information -> Map Versions. You should see "NG4 EUROPE 2021-1".
UPDATING THE RISK AREAS
3. Extract all files from the ZIP file to the ROOT of the USB / SD CARD. Enable in Windows to view "hidden files" and check if any file other than that of the files included in the risk areas ZIP file generated in the root of the USB / SD CARD. If you see any "rogue" files, delete them.
4. Turn on the car and go to NAVIGATION -> SETTINGS -> IMPORT MY POINTS OF INTEREST
5. Select the Media you used (USB or SD CARD) and press YES to validate, that it will overwrite all previous risk areas.
6. After it finishes with the installation of risk areas (takes approx 10 seconds) a message appears to confirm a restart of the NG4 system and to remove the USB/SD CARD. Remove and press OK.
7. When the NG4 System restarts, all you have to do is to enable the risk areas/radars alerts in the Navigation menu. SETTINGS -> RISK AREA SETTINGS -> ENABLE all options.
8. You can check the latest risk areas/radars update in the same menu, that you used to check the MAP Version.
CAUTION. Proceed with every step at your own risk. It is extremely dangerous and it can destroy your NG4 system. No one on this forum or the forum itself is responsible for the caused damage and possible expenses.
I managed to install everything in one afternoon with no issues (my car is RCZ 2013 model). Take your time, follow the steps and it should be fine.
EDIT: Updated the link for the maps and updated the guide a bit - added a photo of how should USB / SD Card root directory look like after copying the files.
EDIT 2: Added the link for Eastern Europe maps - maps from 2020 (Courtesy of Ross_Russev)
EDIT #: Updated the links for MAPS and RISK AREAS - due to new updates.
NF7
Slovenia
I have ng4 sat nav.
Thanks.
Official maps 2016, unofficial fully working maps 2022. Links in the first post.
Andyrcz
Farnborough
I am worried that the 2021 update will cause issues. Any one had any issues with this map. I can’t fond any links to the 2016 maps.
NF7
Slovenia
What kind of issues are you expecting?
As far as I know, 2016 have issues with UK post numbers, while 2021 do not.
Andyrcz
Farnborough
I’m just worried to end up with no sat nav. I guess you can’t go back if I do have issues.
I’ll give it a try. Thanks.
NF7
Slovenia
If you do everything according to the tutorial - you won’t end up without a SatNav.
MiKiller
bih
Hello, i have the problem with my ng4 unit (citroen c5 2010), i updated maps for east europe, for serbia i can se small roads (Novi Sad), but for BiH i can not see roads only some main roads, but i have gas stations hotels and other things on map, and when i insert my adress it shows data invalid as destination. Can you help me?
NF7
Slovenia
Not really sure, as I've never installed Eastern Europe maps on mine. Try installing the regular maps. Or ask Russ_Rusev here via PVT.
vitorlima569
Portugal
Hello NF7 the maps in the first post are from which part of Europe? does it include Portugal? Thanks.
NF7
Slovenia
First post has two different links.
One for Eastern Europe on top and one for Western Europe a little bit lower. Western Europe should include Portugal.
Kirk
Sheffield
I've just tried updating the firmware on the Sat Nav and during the process it failed. Now I have a red screen of death which will not go away. asking for a valid update disk with a HBUPDATE.DEF file. Does anyone know how to fix ? The screen will also not switch off even with the ignition off and car locked.
NF7
Slovenia
Make sure that the correct firmware file and format is on the USB stick and it should go through.
