RCZ-Fan
Deutschland
Hi,
i am not able to start it.
I have a 64 GB SD Card. Formatet in Fat32.
But i have no chance to start Update Firmware or Update Navi Software. I am not so good in Software an Computer things. Maybe one person can helb me, to make it right?
NF7
Slovenia
Use a 32GB USB Stick. Fully format (not Quick Format). It should then work.
Kirk
Sheffield
Make sure you don't have anything in the USB port or CD player. Having something else connected to the Sat Nav seems to stop the install working.
RCZ-Fan
Deutschland
Servus.
SD Card 32 GB Cluster 64 and full formated.
No Chance. It doesn't work..
i extrahiert the file N43 than i copy it on the Card, but no chance, that the card is startin a update
Kirk
Sheffield
Try copying the data within the NG4_N42C folder to your SD card. Not the folder itself. This means the HBUPDATE.DEF file and HEADUNIT folder sit in the ROOT directory of the SD card and not the NG4-N42C folder.
  • Like
Reactions: NF7
beracka
Serbia
Hello,
I can't update firmware or maps on peugeot 308 2013.
I have followed instructions, fully formated 32GB USB sticks and uploaded files which you can see on picture bellow.
When I start the car and insert stick in the USB interface bellow the armrest nothing happens. There is no SD card slot, only USB and DVD.
Maybe it is upgradable only from DVD?
In the car User Manual I have found that navigation system is WIP COM 3D. So I don't know if it supports NG4 firmware and maps?
Please help, thanks in advance!
NF7
Slovenia
Take a photo of your headunit so we can see that your SatNav is actually NG4.
The file structure seems fine. Are you sure you done "full format" not "quick format"?
NF7
Slovenia
I'm pretty sure you have some "hidden files" on the USB stick as the file structure seems fine.
Full format should always resolve this. Also, make sure to select FAT32 and not NTFS. I just tried the files in the first post, and everything worked. The update was recognized and the maps update.
beracka
Serbia
Here is the snapshot of the USB folders with enabled view of hidden files:
I have also checked every other folder for hidden files and I can't find anything.
I have done full format with FAT32 system choice. I believe you that files are good, can you confirm me that my nav system is NG4?
Thanks for reply!
