Re: Changing the DLR / sidelight to LED
Under 2 mins, !!!!!!
I've been out there 2 hours.............
Did you fit the 380/92's ?, they are nearly an inch longer than the standard bulb, so i cannot get the angle to fit them into the holder.
I've also noticed as you reported earlier that they do not seem to dim when the headlights are on, they did when i first tried them but now they stay at the lowest level ?
Maybe your thinking they do not dim, but have actualy dimmed but do not go back to the brightest, if you know what i mean.
This is all making me think is it worth the hassle.
mr shiney said:What exactly are you doing? Mine took under a minute to do both. On the RHS take the air intake off, pull the rubber backing off and twist the bulb holder to remove. Put the LED in the holder and slide it in and twist to lock.
