Great reply RCZ1 and thanks.
So what I get from this are the following:
5. Glad you like the Phillips Extreme, that is why I chose them over others and sell them. To get a true white light a HID conversion is the way to go ;)
Would you say that the 60 LED's give as much brightness as the 92 LED's?
I can't see the Philips Extreme Bulbs on your website, only the Diamond Vision ones. ?
Obviously the 92s have more LEDS but I would say its hard to tell a difference between the two. The 60s are still bright :)
When I turn on my side lights, there is a flicker of the lights, as if it's trying to turn off the DRLs, but they stay on.
I shall continue my survey of DRLs as the nights are drawing in now :(
That is correct I carry the Diamond Vision bulbs as they are better than the X-teme's. The Diamond Vision have a kelvin rating of 5000k, where as the X-treme have a rating of only 2500k, hence why they are not as white as your thought they would be.
I will start to carry the 60's on my site as an alternative to the 92's.
Good news about the 60's.
Jassy put me off the Diamond Vision's as he said they were not so good in the dark on wet roads and the main thing being that they are not road legal in the UK. That's just my choice and I know plenty of other people have the Diamond Vision's and are happy with them :)
I have the red 380/92 canbus bulbs in the rear lights for almost a year now they are far brighter than the standard gls bulbs and are a well worth upgrade,there appearance and colour are far nicer as well :cool:
RCZ-Performance
Banbury
RCZ-Performance
Banbury
I am now selling the 60 LED version on my site (White only as the 92 Red ones for brake lights are still the best):
http://shop.rczperformance.com/DRL-P21-5W-60-White-LED-380LED60SBW.htm
Steve, can you recommend a full front set of normall bulbs that are white/ bluish to replace all the originals.
I want something that works as normal just whiter?
Thanks Scott
Vison Pack or Non-Vision Pack?
Non-Vision Pack:
Dipped Beam:
http://shop.rczperformance.com/Philips-Dipped-Beam-H7-5000K-PDVH7.htm
Main Beam:
http://shop.rczperformance.com/Philips-Main-Beam-H1-5000K-PDVH1.htm
DRL:
There is no upgrade bulb that provides a true white light as in 5000k, the best bulbs I would sell if you wanted better bulbs would be the Philips Vision Plus
I guess you can see a pattern here ;)
Fog Lights:
Unfortunately again there isn't a 5000k, the closest would be a pair of 4500k bulbs.
If you are interested in doing this upgrade you can order the ones I have on my shop and I will add the other ones shortly.
Now the bulbs I sell and recommend are the top-end bulbs, and so the reason they are more expensive than other bulbs you find, is because of the quality etc. of these bulbs.
Scott barton said:
How much for everything then inc fogs?
5000K DIAMOND VISION only suit led drls, these bulbs will look silly next standard drl bulbs there is also a new 28 smds high power fogs out which are even brighter than the ones i have,if i where you scott i would go down the same way RC1 DONE with phillips 100% extreme vision and the 60 smd 380's
RCZ-Performance
Banbury
Thanks Jassy for assisting here with this one.
Scott I can get the Extreme Visions and I already carry the 380/60's. If you want to go to LED in the Fog's I carry those as well (18 LEDs) and can get the 28 LED version.
Just let me know what you want to do
[email protected]
The 28 led's will plough the roads at night and look really cool as drls during the day :cool: and steve i think the 28 smd's will be a match for the HID KIT you sell for the fogs but with the audi drl look :cool: so it maybe worth your while having them on your site as peeps "might think but not know" that the smds are easier to install.
I love having my fogs on during dull damp weather they look like the real Mc coy :cool:
I'm confused here because you would think (or I do anyway) that 60 LEDs would be brighter than 28 LEDs yet Jassy says that 28s are Superbright. Why is that ? Can you explain ?
RCZ 1 I was referring to the H8'S front fog lights
I still need to change the fogs. How easy is this?
For a man man like you Begbie :lol: a doddle :thumbup: just jack the car up takith the wheel af unscrew/unclip 6 fixings and its there for you to see there is NO knuckle stripping involved just a torch is required............... monkeys could do it ;)
Ok I understand. Thanks :)
:lol: :lol: I like the sound of this...and how you put it :thumbup:
Correct me if I were wrong. Isn't fog light better in yellow than white?
Ok ... So the RCZ is going on Monday .. Just changed the bulbs back to standard bulbs and can't believe how bad the car
looks with them.. They really need to look at this on a facelift !!!!
