Bit of a Sat nav issue.
I'm not sure I fancy ordering something from so far away.
Although this is doing my head in. I've searched for one on pretty much every salvage yard website Google throws up.
Rang about 8 today.
None in any 308 cc, 3008, 5008 and only one on Ebay. Which I made an offer on but got completely ignored, so he can go forth and multiply.
I'd swap to an aftermarket unit, but I don't want to end up gimping the car even more than it is!
frankvdb
Eindhoven (The Netherlands)
I am pretty sure that the dealer can change the code in the NG4 so that it works in your car.
There are people who have that P2000 software with which you can do that through the OBD2 interface.
Yeah, I've got planet so can do it myself :mrgreen:
Sent from my Vodafone Smart ultra 6 using Tapatalk
If I get hold of one from a Citroen, will updating the firmware mean it knows its in a Peugeot?
Or will it be stuck with a Citroen splash screen?
Ah yes mirascript, unlocked some themes on my 508 with that . Thanks.
Ahem....
The 5008 faceplate is a clue...
Done, and now watching ghost busters in the worlds smallest cinema :p
ONLY AEK
greece
Glad you made it
I try to installer An rt6 but i find Nothing but problems till now
How was the wiring? Did it just plug in?
Well, all seems well.
I updated the firmware and it worked fine.
I now have the newer loading screen.
The maps can wait a little while until I get some more fiddling time.
Going to install some heavy metal on the jukebox later :)
Have you tried a factory reset?
no idea if it would help, but easy enough to try.
I hadn't a very similar problem with my RT6 unit, and I know of a couple of others that had it also.
It was rectified by the replacement of the GPS aerial by the dealer. I was fortunate, as it was done under warranty.
Hi all,
Yeah tried reset gonna book it in n see what dealer say.
Cheers
Can anyone point me in the direction of checking my map version?
I've tried the secret menu bit, but unless I'm blind it doesn't mention it in there.
Thanks.
