Water leak
Bang308
Oxford
Hi all , went to start the car this morning found a water leak it seems to be cracked on the hard plastic piece on this top hose this there an easy way to remove it or do you have to remove most of the front bumper to do it. Many thanks Tony
Kerr
Are you sure you've got a leak? Are you sure it's not just condensate from the air conditioning?
Bang308
Oxford
No Kerr definitely a leak ,the hard plastic piece on the left is cracked
Apparently the Rad can be removed with the bumper still on the car
Bang308
Oxford
Thanks for replying Pedro , it's just the hose i need to remove. In the picture it's the part just by the kink to the right seems to be fixed back scuttle panel. left hand side is removed from the rad it's on a 200gt
I'll check that 2morrow mine's also the 200GT this diagram is I believe for the 156
Bang308
Oxford
Thanks Pedro, it's the hose that runs across the top of the scuttle left hand side drops down to the rad, right hand side is fixed with a jubilee clip to the hard plastic piece i can't remove
Hoses from Peugeot parts direct looking at your pic & the diagram it appears it all one part ?
Bang308
Oxford
Yes that's the part (2) Pedro , it's part (71) the screw i need to remove .do I have to remove bumper or does the scuttle come of has a separate part to reach that screw. Thanks Tony
I'm sifting through some files to see if I can find a better angle it looks like 71 is a screw for the hose carrier which may be accessible according to the build diagrams below but I'm thinking that bolt/screw is removable from the inside top under the scuttle tray
