HARWOOD said:Well after it seemed to have settled down - rising normally it suddenly went bonkers rising from one side of the dial to the other several times with a "Temperature fault - stop car" warning flashing in Red on the dashboard and latter a "Compression fault" warning flashing in Red also. It is currently at the dealers awaiting a new temperature sensor to be fitted.
I have had the car from new from 05.03.2011 and it has been in the garage three times - previously for a new spark plug which did not cure the previous fault and was later identified as a faulty ignition coil.
I am very much starting to regret owning an RCZ![]()
This is also happening with mine re temperature fault stop car warning flashing in red, I push the excellator and the temp go's back to normal?? Has been happening for three weeks. I informed the service department last wek when they did the 20k service but it is still happening?
