Steering wheel vibration around 75mph
NF7
Slovenia
I was investigating this myself at home, and I suspect tie rod end (not sure if it is the correct term) on the left side went bad as it had some "gap" while trying to shake the wheel. It was fine on the right side. The car is going into the shop on Wednesday to fix. It should be a one hour job.
That's a cheap and quick fix.
Strangely those never went bad on my +200.000km R. Driving fast all the time pays off ;)
  • Love
Reactions: NF7
RCZKam
Yeah, I've used both shops before as friends work there (sometimes the first shop is so full that they cannot squeeze me inside so I use another one).
Not that everyone can but do you know of another rcz owner you can swap wheels with to rule yours out? Local club etc
NF7
Slovenia
I've seen two RCZs in my area in two years of owning it.
NF7
Slovenia
UPDATE:
Tie rod end on the left was completely gone, and was about to go on the right. Both replaced.
Ball joint was completely gone on the right, and the left was somewhat fine. Both replaced.
I have also went to get my wheels aligned and balanced.
Vibration 90% gone. I'm suspecting the rest on the aged suspension (probably will change it in the winter) and summer tires (next year). The worse of the vibration is completely gone - no more severe vibration while turning left/right.
Yea the whole front suspensions on these take a right hammering
  • Like
Reactions: NF7
