Smoke after idling = valve stem seals?
Nemi
Lithuania
How logical is to replace timing chain at the same time you replace the valve stem seals? As I understand, you have to take it out either way as you have to remove the cams.
The car is on 120k with the original timing chain.
My Peugeot specialist suggests changing the timing chain every 80k km on these engines.
Mikefrank
Swansea
Knocking on the door of an old thread here but I’m getting puff off smoke from idle when engine is hot….plus im knocking on the door of 120k…..
Currently running Castrol Edge 5-30….any you guys running 5-40….:unsure:
NF7
Slovenia
Won't help you. You'll need to replace the valve stem seals and you'll be good for about 50k miles. Then its going to start again. So probably not worth doing the fix.
It would be advisable to do a compression test first, the problem could also be coming from the piston rings.
Mine did the same the end result was Head off & refurbished all valve ports cleaned out & seals replaced with the chain set its false economy to just change the seals without cleaning the ports of carbon build up its pricey but if your keeping the car you notice the gains in acceleration & better engine performance as all the crap in the head affects these engines no matter what the car model I read a service schedule that the benchmark for direct injection carbon cleaning is approx. 60.000 Klms
