silicone hose thp270
NF7
Slovenia
Can’t order just one pipe ?
I believe the red one on the picture is the silicone one, the black one is the original. The photo is just comparison between the original and the custom.
Marmite
sorry that’s not what was getting at what I meant was as your looking at the engine on the left side u have another plastic pipe that goes to the air box an does this pipe suffer like the one on the right of the engine bay from breaking up inside ?
  • Like
Reactions: NF7
reycz95
FRANCE
the pipe from the intercooler to the air flow meter ????
reycz95
FRANCE
the rigid pipe on the left above the distribution does not go to the air filter but to the intake manifold, this one does not move, on the other hand this original shape is not ideal for good air circulation this is why, as I did forge at the time, I am remaking it in aluminum
Hi reycz95,
Attached you will find the pictures of the pipe which was falling apart in my R.
You are free to use those pictures for your own purposes.
Marmite
Which pipe was this ? My pipe from the air box to cold intake on turbo is a bit scaly inside but nothing like that in your pics , where mine failed was on the rubber seal between the pipe an the turbo but Iv sleeved it with a silicone joiner an is working fine for now
Jh72i
has it got a jubilee clip or like the inter cooler side a spring clip an yes I have created a account
You should contact them as I am led to believe their bank can only accept French credit cards but that they do have paypal and bank transfer options. I know how odd that sounds but..!
It has been a while since it occurred but if I remember correctly it was pipe no. 4 as on the blueprint attached to the first post here.
reycz95
FRANCE
the one to enter air filter and turbo should not delay to be delivered, the other 3 not before the end of July just like the high volume intercooler
Marmite
Very nice I’d got black though as I want a stock look, do you get any issues with not having the heating wire not being able to be used
Marmite
Just going of the subject a bit I see you got the dreaded pink dust on your engine from the fibreglass matting attached to the alloy shield , well I took mine off an replaced it with some heat shield blanket cut to shape to fit under the alloy to give it more protection from frying the cam cover gasket from flee bay an no more dust
reycz95
FRANCE
those who ordered during the promo the hose between air filter and turbo it is coming soon
the other 3 (intercooler entry and exit at the end of August ~) and the most anticipated high volume intercooler not before September
