Should I be concerned?
OkeyStokey
Noticed some oil around (what I presume is) some form of sensor near the turbo. (THP200).
Anything to be concerned about?
Looks like Oil vapor discharge check the hoses it may just be blowing off somewhere
OkeyStokey
Thanks Pedro. As in a seal, or poor fitment?
So that oil is supposed to be in that region, just inside not out?
You should not see any Oil on the outside of the hoses & that appears to be concentrated in one place it looks like the hose has/is failing around the joint as that is the Oil vapor pipe to the rocker cover problem there is its connected to the Turbo intake & could easily mean its blowing out from the Turbo itself & escaping through the joints I'm wondering if you might have a sticking wastegate problem?
take it off & clean all the gunge from the hose & keep a close watch to see if any new discharge appears within a few days
OkeyStokey
Once again, thanks Pedro.
I have removed the pipe & cleaned the area. I noticed the pipe has a small keyhole cutout at the end/rear. Looks too neat to be a rip, but don't know if this is the problem?
Goatz
London
That’s normal... well at least on an aftermarket, I can confirm that
The Keyway is for the sensor housing to fit flush into the pipe nothing to worry about just check it periodically to see if its a leaking joint
