Roof Arches Seal
The seals are fixed to the actual arch and very likely to be OK as they just sit against the roof and the windows
NF7
Slovenia
What about the window seal? The one you have to remove to access the screws on the bottom side?
You take off the window wiper arms off 17mm then you can remove the washer cover by removing the two fixing each side and pulling the cover out of the seal then remove the bolt from the arches to the front open the door to remove the door seal from the top and side of the door to the front (don't remove seal completely ) then there's 8 small torque screws with these removed you can remove the arches BUT YOU WILL NEED TWO PEOPLE AS NEEDS TO BE HELD AS TO PREVENT DAMAGE AT THE FRONT NEAR THE BONNET... Place a rag or cloth in the gap.
When removing pull up towards you...
Hope this helps you out...
  • Like
Reactions: NF7
Yes door seal is quite sturdy goes back easily 👍
  • Love
Reactions: NF7
