Replacement RCZ with Xenon headlight lens
Geoff Anson
Sysney
Hi to all RCZ lovers. Can you replace the plastic cover without replacing the entire light unit?
If you mean the lens I doubt it unless I'm wrong there all sealed Units to stop water ingress
Ecrivain
South Norfolk
Why, is it broken, or just obscured by age and plastic deterioration?
I recently came across a car for sale with one perfect headlight and one very yellowed!
Sadly I suspect the previous owner had failed the MOT, but the tester kindly let them do one this year and one next.
(This happened to me with an old C Max! Fortunately, I managed to clean both sufficiently to avoid immediate replacement - by buffing gently with a special pad attached to an electric drill, IIRC...)
Aren't you supposed to be able to clean these up with toothpaste or something according to the internet...?
K50 AOS
Glasgow City
Can defo be split then resealed if needed
Remove unit big cardboard box add hole enter hairdryer or heat gun on low 10mns n they split easy
Swap for tinted or normal lense replacement or go the simple route n buff with high grade n polishing ointment
My local body shop offers a refurb service for £60 guaranteed to look like new again. Mine aren’t bad, but might get them done in the future.
K50 AOS
Glasgow City
It's acetylene they use metal can video on YouTube looks like a tea pot with an element mask of the bumper then from an inch away heat up the solution and go over the cloudy parts will come back in time it's UV rays that discolours them so not a permanent fix I had a guy who sold the lenses for 50 a piece he's gone now it was on Ali express none left
