Rear view mirror
Mick B
Wakefield
Hi all, new to site, first rc, mirror has delaminated so need to remove whole unit, anyone know how? Thanks.
chrismac
Cardiff
Twist off / twist on. I found it a bit tricky but managed eventually.
dumdum
Mansfield
Be very careful twisting you don’t pull… it’s very possible with enough force to shear the glass… ask me how I know 😂
Also, if you use something as a lever, insert the lever just a little because if you insert it too far it can break the adjustment motor.
It is best to push the glass from above so that it comes out from below and try to separate it only with your fingers by pulling from below.
dumdum
Mansfield
Rear view not side mirror… he’s not removing glass from the rear view mirror
