Peugeot 3008 Hybrid Radio
Mahlig
York
I have a Peugeot 3008 Hybrid 4 and recently had a electrical problem with the NG4 3D Connect Media Navigation system. I turned on the ignition there was a flash a crackle and smoke emerged from the CD bay and dashboard vents. I bought a replacement 2nd hand unit and fitted it. At that stage everything including the volume control worked. The radio then started to beep. I got my local garage to change the Vehicle Vin on the radio and again everything works appart from the volume which is too loud and will not alter. I have tried a factory reset but it does not work. I have tried holding down the volume button and the CD eject button. It resets but the volume is still uncontrollable. I have tried a sound reset bit nothing happens. Any suggestions please.
Thank you. Should I attempt to reboot BSI
You could try it & if it wont reboot the system then you may need to default it & possibly reinstall the programme the problem with aftermarket upgrades is they are not all compatible with the original factory equipment which can be locked in the cars BSI ECU configurations
Mahlig
York
Thanks for you advice. It is much appreciated.
