Pcv valve
Scott1973
Gravesend
Glad you got it done I had the same problem it was split down one side. It might take a while to notice the difference as you might have oil residue in the exhaust which will burn off in time
  • Like
Reactions: NF7
Gina0151
Wirral, England
There is some confusion here.
That I know, there are at least 3 different rocker covers:
This is the one I have
But looks like also these are sold as compatible for the Mini:
View attachment 12027 View attachment 12028
Only on the second two, it is possible to replace the PCV.
Maybe it is possible also on the original one (the first picture), but this mean rip off the top cover and glued it back after the PCV is replaced.
Mine’s the top one, same as yours Valex. My RCZ is a 2011 GT THP 156. So Does this replacement rocker cover include the PCV valve built into it and not a separate part? On the 156 model
Gina0151
Wirral, England
My rocker cover and gasket on my 2011 IMG_1024.jpegRCZ 156 model is being replaced with a new one this week by the garage. So according to the info in this thread the new rocker cover has the pcv valve incorporated inside as part of it? Am I correct?
Just checking so that if they start charging me extra for a new PCV valve in addition then they’re either ripping me off or they have the wrong rocker for my 156 model?
NF7
Slovenia
My rocker cover and gasket on my 2011 View attachment 15145RCZ 156 model is being replaced with a new one this week by the garage. So according to the info in this thread the new rocker cover has the pcv valve incorporated inside as part of it? Am I correct?
PCV valve is incorporated into the entire cover. It is not replaceable on the 156. It is replaceable on the 200. It is also not a valve, but a membrane.
