Valex
- Joined
- Jan 29, 2021
- Messages
- 165
- Reaction score
- 118
- Points
- 43
- Location
- The Netherlands but Italian :)
Update ...
I drove back home, and all the gauge values on the app were the same as this morning.
In acceleration, the oil pressure gauge goes over the 100 PSI (101-102). That is the reason I changed the max value of the gauge to 200 PSI.
Again, the check engine light went off after 2-3 seconds after I turned on the engine and the "Engine Fault: repair needed" never came out.
But arrived at home the fan was on and it stayed on until I disconnected the battery .
This is the export file from the Car scanner app In red the description I found on internet
Car Scanner ELM OBD2
DTC report
Selected brand: Peugeot
============1==============
P15A6
Raw code: 15A6
ECU: Engine control unit#3
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
P15A6 Engine Oil Pressure Too High Before Start
============2==============
P0948
Raw code: 0948
Status: Test is inhibited by other DTC, Validated, and stored in non volatile memory
OBDII: Hydraulic pump relay - circuit high
P0948 Hydraulic Pump Relay Circuit High
============3==============
P15A8
Raw code: 15A8
Status: Pending fault present, Test conditions are met, Validated and stored in non volatile memory
P15A8 Lubrication system : Pressure not consistent with the atmospheric pressure
============4==============
P0522
Raw code: 0522
Status: Pending fault present during this driving cycle, Test conditions are met, Validated and stored in non volatile memory
OBDII: Engine oil pressure sensor/switch - low voltage
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
============5==============
P15A7
Raw code: 15A7
Status: Pending fault present, Pending fault present during this driving cycle, Test conditions are met, Validated and stored in non volatile memory
P15A7 Engine Oil Pressure Too Low Before Start
============6==============
P15A6
Raw code: 15A6
ECU: Engine control unit#4
============7==============
P0948
Raw code: 0948
============8==============
P15A8
Raw code: 15A8
P15A8 Pressure not consistent with the atmospheric pressure
============9==============
P0522
Raw code: 0522
P0522 Oil pressure sensor signal : Short circuit to earth
============10==============
P15A7
Raw code: 15A7
P15A7 Oil pressure too high in relation to the atmospheric pressure
DTC report
P15A6
Raw code: 15A6
P0948
Raw code: 0948
P15A8
Raw code: 15A8
P0522
Raw code: 0522
P15A7
Raw code: 15A7
P15A6
Raw code: 15A6
P0948
Raw code: 0948
P15A8
Raw code: 15A8
P0522
Raw code: 0522
P15A7
Raw code: 15A7
