Multifunction display panel
KDrcz
HI Guys today my Multifunction display panel on my dash has gone blank
car still drives well radio works but panel is just showing orange even when switch off
with key out of ignition.
Help appreciated thanks. k
Have you checked the fuses in the glovebox ? Is anything else not working ?
KDrcz
Management light is on but car drives ok...everything works
apart from the display just showing orange even with key out.
Thanks K
If your management light is on, you should be able to get a code(s) using an obd2 reader. This might relate to the issue with the display not working but still showing orange when the car is off.
Obd2 readers can be obtained from many sources on the internet, and range from just a few pounds upwards.
Once you have a code(s) depending on the reader, you will be able to find d out what this refers to. If you post the code on here, there are members that will be able to help with the meaning of the code.
It might be that the management warning is unrelated to the display fault, but at least its a place to start.
KDrcz
Hi Guys..just to let you all know iv'e manage to get the multifunction display working again
took it to my local garage ...what they did was to reboot the radio by taking both leads from
the battery for around 20 mins problem solved..in case this happens to anyone else
just remove battery leads.. paid them £25 happy days.
THANKS K
AKA a BSI reset. Easy enough to do and can solve all manner of Peugeot-isms.
I've had all sorts over the years. The climate control in my 406 stopped working properly, BSI reset.
Both my 407s had mental electric windows, BSI reset.
And my RCZ decided to show the mileage in kilometers one day, BSI reset.
Modern Peugeots are very picky with batteries, if you do start getting spurious bleeps and lights and have an old battery just swap it for a new one.
Hi,
does this work for RCZ's ?
I'd like to swap my old RCZ for a new RCZ, will that be OK? my old ones getting quite high on the miles now.
PS. you finished with that diagnostic tool yet, you know the PSA group one with the diagbox thingy....
since you've got yersen a GT you might want to part with it?
Dale
UK
THANKS K
Hi,
I've got the exact same problem. Just confirm you disconnected the battery for 20 mins? Did you need to put the radio code back in again once the battery was connected????
thanks
You could do a BSI reset instead of disconnecting the battery For 20 minutes.
equipment is switched off.
ignition.
15 seconds.
not open doors.)
BSI related items.
Dale
UK
Will I need to re-enter the radio code if I disconnect the battery for 20mins??
Found this old post which may help anyone who gets the engine fault repair needed icon,
I think it’s interesting as the solution came from Peugeot assist5D603C6B-210C-4677-A693-EA892C34D461.jpeg
