Intake system
KreyzoR
Poland
Hi, i was looking for a while a dediacted intake system for my rcz 200hp but i couldn`t find any, have you guys made it by yourself or you bought it on some site ?
Please let me know, have a good day all!
JazzyRCZ
Gtintake will be releasing one soon, find them on Facebook
Intake systems that take the air from the engine cavity reduce engine power somewhat, since the cavity hotter air is less dense than the air that is taken from the outside as in the standard intake.
They can play havoc with the MAF sensor & modern engines prefer cool air injection from the intakes
det09
Dortmund
Gibts schon etwas länger.
Why didn't you just put a K&N panel filter in the original airbox?
det09
Dortmund
Wie ich schon schrieb geht es um TÜV-konforme Lösungen.Selber fahre ich den Orginalfilter da nach Aussage des Tuners erst bei einem Laderupgrade ein anderes Filtergehäuse von Nöten ist.Ich fahre zur Zeit mit 303 PS und 400 NM durch dien Gegend.Das funktioniert sehr gut auch ohne Ansaugseitiger Anderung.
Basically he posted the info about the carbon fibre airbox from some firm TUV compliant solutions but he is apparently still using the normal air filter as his mechanic says a different filter housing is used in a Turbo upgrade his z is remapped at 303HP & 400 Nm which is plenty of power without any air intake mods
