hurrican
Slovakia
Thanks so much for pointing me in the correct direction. I managed to fix the audio issue as well as an issue whereby my steering wheel button to change audio source wasn't working. I've updated my previous post on this thread to detail what to do. 😁
What I don't get on the screen anymore is the indicator if I open a car door, or the "Checking" progress messages if I press the "Check" button below the speedometer. Any ideas on these? Surely it's another setting or two that enables these. Settings which aren't covered by that script.
EDIT: I fixed the above as well (having the screen show me when car doors are open, pop-up messages, etc. This is more complicated. You need to download the original MiraScripts (this is where the Deactivation of Activation Code files come from) for the RT6. You run this on a USB stick and select an option that saves your RT6's entire configuration on to it. This USB stick is then plugged into a computer with the program DatExplorer that allows you to edit specific RT6 settings one by one. This is where you find and enable the pop-up messages on the RT6. You can customise a lot more here too. Once you save changes, you plug in the USB stick back into the car and instead of saving the configuration, you replace it with your modified one. A reboot of the RT6 and it's done. The RT6 MiraScripts and DatExplorer are all available through here: http://mira308sw.altervista.org/en/
If anyone needs any help doing this, I'm happy to guide you.
Hi, i have the same problem with no pop-up door (check button work fine). I tried your guide, copy config files to usb, but checked all 3 files (User_4 , User_com and User_config.dat) but cant find where to eneble that pop-up doors. Could you help please or anybody who solved this problem.. Thanks
Edit : Also i have problem while makeing phone call, that opposite site (caller) hear himself twice.
Karvanswd
Poland
Hi
I new owner of 2012 RXH Hybrid4 Peugeot and I had follow this post with my SDCard problem - Card was replaced by new - soft was implemented (2.86B), audio sound turned on and required maps installed. Pop up inforamation and wheel steering are also working good - but there is few problems to solved.
1. on the dashboard there still information that radio and navigation are turned off but on the main navi screen radio and navi are working correctly.
2. before soft breake down I have 2 additional screen with Hybrid info (1st with Hybrid % usage/min, and 2nd with car visualization with battery/engine current usage) after above operation there is only Audio screen, maps and compass/maps screen.
off course there is still mic calibration to do as there is echo during phonecall - but as am aware it can be done only by Peugeot service
anyone have an idea how to proceed with remain problems?
rejdmen
Zemun
Hello all,
I followed thorough guidelines here and I started updating from 2.20 to 2.86. The corrupt USB was sorted out and the update began. It lasted for about 25minutes restarting and everything until it booted and showed the map in the background and in the foreground message "insert navigation CD". At some point (as I was driving and was distracted) I couldn't get that off the screen and I pulled the USB out. Now the screen turns on but all black. I even opened the console and noticed that unit was still working, but nothing showed on the screen.
Anyone had this problem or know how it can be solved?
PUG 508 2012 2.0.
newkiebrown
Newcastle
Can I just confirm the map update deactivation part please?
I went through and changed nothing except for the last one but then found my other SD card wasn't readable so had to clear the one I had and install the Map updates on it. I wasn't sure whether I'd need to do the deactivation again, but can I just check that the purpose of the deactivation is to change the Maps DRM setting to 1 and it will stay like that after reboot, allowing map installation?
bozur
Zagreb
Hi,
I have same problem as you, with no pop-up messages and not showing doors are open.. after changing faulty sd card. Please can you help with procedure to restore these options back ? Thanks!
Kind regards
I have a same problem after changing SD card, no open door message, no low fuel message, no below 4° temperature and possible ice...
johnrid
lancashire
Here is a how to guide for updating the RT6 system
These updates are for the RT6 (or RNEG) system only
The order I would do these in is
1) Firmware 1st
2) then Maps
3) then Risk Alerts
You will need at least 1 usb drive. Format to FAT32 for the car to be able to use it.
Everytime you download a zip file all files on USB have to be delete first!
Although the size of files are just below 4gb, due to the formatting process there is not enough space on a 4gb USB stick.
For the Maps you will require 1 x 8GB or greater (up to 32GB).
Link updated 1st October 2021
Extract the zip file to the USB stick so when you open the stick on PC it looks like this
One this is complete you can then update the car by plugging in to the USB socket in the arm rest storage area and following the on screen prompts.
To update the maps, but you have to do one at a time.
It takes about :- Italy -20 minutes
France - 30 minutes
Spain & Portugal - 25 minutes
Benelux - 20 minutes
UK - 20 minutes
Scandinavia - 25 minutes
Germany - 25 minutes
Middle Europe - 15 minutes
Southern Eastern Europe - 15 minutes
North East Eastern Europe - 20 minutes
North West Eastern Europe - 25 minutes
I would go for a drive whilst doing the updates (more beneficial to the car than being sat at tick over)
Then inserted the Risk Area alerts disc - a few minutes (really quick)
The ones below will probably go on a 1GB USB stick
If during the update of the maps you get a request for activation code, you can use the file Deactivation of activation code (instructions included).
This is where a 2nd USB stick is handy its only a small number of file probably less than 500kb.
The deactivation can be reversed at any time.
Risk alerts - basically about speed camera, there are monthly updates, again the size of files are small less than 4mb
This is usually one month behind current month eg if its August the latest will be July, I will probably post on forum and facebook that I have updates files!
Firmware update – this is the 2.86 firmware, again the size of files are small less than 80mb
I will post notification when folders are updated.
Any queries send me a PM and I will respond as soon as possible.
Chris
Edit
For those of you trying to update from 2.75 to 2.86 it might not work.
Might have to go from 2.75 to 2.80
From 2.80 to 2.86.
I will have my original disc 2.80 firmware update disc back soon.
But here you can download it from gpsunderground.com
Try this from gpsunderground.com
http://gpsunderground.com/forum/peugeot ... post237136
Post 33 is the iso file to download.
Post 40 is interesting (has to be done from disc not usb).
johnrid
lancashire
1) Firmware 1st
2) then Maps
3) then Risk Alerts
France - 30 minutes
UK - 20 minutes
Chris
Edit
From 2.80 to 2.86.
igaljuf
Velika Gorica
ja sam imao problem sa svojim 508 sw 2013.Bas u subotu rijesio.Poceo se radio u voznji gasavat i palit.
Zvao u Francusku odmah mi rekli da je sd card.
jer kod nas u Zagrebu nemaju pojma o nicem.Odma bi mijenjali radio i uzeli 1138 eura za njega.Imao sam isto rneg 2.75,stavio ga na 2.86
igaljuf
Velika Gorica
I just wanted to update on my situation above because I have no doubt someone will have this issue and will be as desperate as I was. I managed to fix it!
The culprit is the RT6's MicroSD card. Inside the RT6 is an 8GB MicroSD card that stores the firmware. As with everything, these can become corrupt over time and fail. This causes a myriad of issues such as the RT6 crashing and rebooting, the RT6 getting stuck in a boot-loop, the RT6 saying "Checking in process" every single time you start it, the RT6 failing to upgrade firmware as mine did, etc.
The fix is simple - it needs a new MicroSD card. You first need to remove the RT6 unit from the car. I used the following YouTube video of a Peugeot 308 that has the same dashboard layout as my Peugeot RCZ (it has English captions you can enable):
Once you have the RT6 in your hands, you can follow this guide to change its MicroSD card:
How to Replace the Internal MicroSD Card - RT6 - French Car Forum
I didn't do the battery disconnection procedure. I simply left the car off with the battery connected the whole time. Anyway, the RT6 does not support a MicroSD card larger than 16GB. I found a Sandisk Class 10 (high-speed) 16GB MicroSD card for €5 and went with it. You do not need to format the MicroSD card first. Just take it out of the original box and put it into the RT6. The RT6 will format it once you install firmware on it.
Now, since the MicroSD card is blank, the RT6 will start with a blank screen and the disc drive will make a noise every 30 seconds or so, as if seeking a disc. You will need to use a USB stick to flash the firmware on to the RT6. You can download the RT6 2.86 firmware from the links posted above by tianorth.
The USB stick you use must also be 16GB or smaller. Format it on a computer with the FAT32 file system. Once blank, copy over the contents of the RT6 2.86 firmware update on to it. Then, open the Windows Command Prompt in administrator mode. Note which drive letter in Windows is your USB stick (say it's E drive), then type:
del "E:\System Volume Information"
This is a hidden folder Windows creates on newly-formatted USB sticks and its presence makes the RT6 firmware update fail. As soon as you use the above command to delete the folder, unplug the USB stick from your computer and do not plug it back in (as it will re-create this folder when you plug it back in).
Insert the prepared USB stick into your car's USB port and switch on the car's engine. The RT6 will pop up and say "CRC checking media" as it reads the USB stick you plugged in. It will flash the firmware automatically. After about 15 minutes (with a new, high-speed MicroSD card, this is what it takes), you'll be sorted!
An issue you may have after you do all this, is lack of audio output from any source (Radio, AUX, Bluetooth, etc). At least this was the case for me with the JBL addon for my RCZ. The button on your steering wheel to change audio source may also not work anymore. To fix this, you need to now use the Deactivation of Activation Code files posted by tianorth above. You need to repeat the process above to prepare a USB stick with this. Namely, formatting the USB stick (16GB or smaller) as FAT32, copying the files over and then deleting the System Volume Information folder that Windows generates, using the Windows Command Prompt.
Nakon što je vaš USB stick pripremljen, umetnite ga u automobil dok je automobil uključen i ekran će vam početi postavljati niz pitanja Da ili Ne . Odgovorite Ne na sve dok vas ne pitaju o audio modu . Evo, za mene je trenutno postavljeno na 3 i pitali su me želim li ga promijeniti na 4 . Za JBL dodatak na vašem RCZ-u morate ga postaviti na 2 . Samo odaberite Da više puta dok se ne postavi na 2 (kružit će kroz vrijednosti). Nakon postavljanja na 2 odaberite Ne za nastavak. Opet, odgovorite s Ne na sve dok vas ne pitaju o tomeVMF/VCCF . Ovdje provjerite je li postavljeno na 0 . Moj je bio postavljen na 1 i pitao me želim li ga promijeniti na 0 , na što sam odgovorio Da . Nakon postavljanja na 0 , nastavite odgovarati Ne dok ne dođete do pitanja na Maps DRM . Ako je ovo trenutno postavljeno na 1 , odgovorite Da da biste ga promijenili na 0 i zatim nastavite. Na kraju će vas pitati želite li se ponovno pokrenuti. Definitivno odgovorite Da ovdje, jer je ponovno pokretanje potrebno za primjenu postavki. Kada se zaslon isključi radi ponovnog pokretanja, izvadite USB memoriju iz automobila.
Kada se vaš zaslon vrati, ponovno će raditi vaš JBL audio, kao i tipka na upravljaču za izvor zvuka. Nakon postavljanja Maps DRM na 0 , sada vam omogućuje instaliranje karata i upozorenja karata prema uputama u ovoj temi. Možete ostaviti i ovu postavku kakva jest (ne morate je mijenjati natrag na 1 ).
Za referencu, pronašao sam što svaka od vrijednosti Audio Mode predstavlja:
0 = normalno (interno pojačalo)
1 = Hi-Fi (vanjsko analogno pojačalo)
2 = Hi-Fi CAN (vanjsko digitalno pojačalo)
3 = Arkamys (interno pojačalo s Arkamys DSP audio)
4 = Arkamys + Hi-Fi (vanjsko analogno pojačalo s Arkamys DSP audio)
Probao sam 3 (zadano postavljeno kada sam popravio svoj RT6) i 1 . Nijedno nije radilo s mojim JBL dodatkom. Čini se da je 2 ispravna postavka.
Nadamo se da će gore navedeno nekome pomoći.
Moze pomoc,imam mali problem nakon azuriranja na 2.86.Hvala
igaljuf
Velika Gorica
bok
Novi vlasnik 2012 RXH Hybrid4 Peugeot i pratio sam ovu objavu sa svojim problemom sa SDCard karticom - kartica je zamijenjena novom - soft je implementiran (2.86B), audio zvuk uključen i potrebne karte instalirane. Skočne informacije i upravljanje kotačima također su dobre - ali postoji nekoliko problema koje treba riješiti.
1. na kontrolnoj ploči i dalje postoje informacije da su radio i navigacija isključeni, ali na glavnom navigacijskom ekranu radio i navigacija rade ispravno.
2. prije mekog prekida rada imam 2 dodatna zaslona s Hybrid informacijama (1. s Hybrid % upotrebe/min, i 2. s vizualizacijom automobila s potrošnjom baterije/motora) nakon gornje operacije postoji samo Audio zaslon, karte i zaslon kompasa/karte .
Naravno, još uvijek treba napraviti kalibraciju mikrofona jer postoji jedna tijekom telefonskog poziva - ali koliko znam to može učiniti samo Peugeot servis
ima li tko ideju kako nastaviti s preostalim problemima
bok
Ja novi vlasnik 2012 RXH Hybrid4 Peugeot i pratio sam ovu objavu sa svojim problemom sa SDCard karticom - kartica je zamijenjena novom - soft je implementiran (2.86B), audio zvuk uključen i potrebne karte instalirane. Skočne informacije i upravljanje kotačima također rade dobro - ali postoji nekoliko problema koje treba riješiti.
1. na kontrolnoj ploči i dalje postoji informacija da su radio i navigacija isključeni, ali na glavnom navigacijskom ekranu radio i navigacija rade ispravno.
2. prije mekog prekida rada imam 2 dodatna zaslona s Hybrid informacijama (1. s Hybrid % upotrebe/min, i 2. s vizualizacijom automobila s potrošnjom baterije/motora) nakon gornje operacije postoji samo Audio zaslon, karte i zaslon kompasa/karti .
Naravno, još uvijek treba napraviti kalibraciju mikrofona jer postoji jeka tijekom telefonskog poziva - ali koliko znam to može učiniti samo Peugeot servis
ima li tko ideju kako nastaviti s preostalim problemima?
Ko ste riješili problem?
hvala
igaljuf
Velika Gorica
Puno hvala što ste me uputili u pravom smjeru. Uspio sam riješiti problem sa zvukom, kao i problem zbog kojeg tipka na upravljaču za promjenu izvora zvuka nije radila. Ažurirao sam svoj prethodni post u ovoj temi kako bih opisao što učiniti.😁
Ono što više ne dobivam na ekranu je indikator ako otvorim vrata automobila ili poruke o napretku "Provjera" ako pritisnem gumb "Provjeri" ispod brzinomjera. Imate li ideja o tome? Sigurno je to još jedna ili dvije postavke koje to omogućuju. Postavke koje ta skripta ne pokriva.
EDIT: Popravio sam i gore navedeno (da mi zaslon prikazuje kada su vrata automobila otvorena, skočne poruke, itd. Ovo je kompliciranije. Morate preuzeti originalne MiraScripts ( ovdjedolaze datoteke za deaktivaciju aktivacijskog koda) from) za RT6. Ovo pokrećete na USB sticku i odaberete opciju koja na njega sprema cijelu konfiguraciju vašeg RT6. Ovaj USB stick se zatim priključi u računalo s programom DatExplorerkoji vam omogućuje uređivanje određenih RT6 postavki jednu po jednu. Ovdje možete pronaći i omogućiti skočne poruke na RT6. Ovdje također možete prilagoditi puno više. Nakon što spremite promjene, USB stick vratite u auto i umjesto da spremite konfiguraciju, zamijenite ga svojom modificiranom. Ponovno pokretanje RT6 i gotovo. Svi RT6 MiraScripts i DatExplorer dostupni su ovdje: http://mira308sw.altervista.org/en/
Ako nekome treba pomoć u ovome, rado ću vas uputiti.
Moze pomoc?
hvala
308cc
Whiteley
Hello tianorth
Just getting all the bits in place to update everything, including the internal sd card.I have swapped my RNEG for a RNEG2 RT6 and a couple of niggles to solve.
Are you aware if your guide works for the 308cc?
Ta
Mike
newkiebrown
Newcastle
I used this guide and updated to the latest software but only updated UK as that's all I really needed. It worked a treat once I'd figured out the SD Card was my enemy and nothing in the post. As I only had one I had to wipe and install the maps after the software update but that was all good. It didn't matter they were hours apart :)
tomaszslabosz
thetford
Hi All,
I did update my radio to latest software and after everything is finished all is in Czech language. I tray change that without any luck.
Can somebody tell me how to change to English please...
zuberismail
uk
Once your USB stick is prepared, insert it into the car while the car is on and the screen will begin asking you a series of Yes or No questions. Answer No to everything until you are asked about Audio Mode. Here, for me it was currently set to 3 and I was asked if I wanted to change it to 4. For the JBL addon on your RCZ, you need to set it to 2. Just select Yes multiple times until it sets to 2 (it will cycle through values). Once set to 2, select No to continue. Again, answer No to everything again until you are asked about VMF/VCCF. Here, make sure it is set to 0. Mine was set to 1 and it asked me if I wanted to change it to 0, which I answered Yes to. Once set to 0, keep answering No until you get to the question on Maps DRM. If this is currently set to 1, answer Yes to change it to 0 and then proceed. At the end it will ask if you want to reboot. Definitely answer Yes here, as the reboot is needed to apply the settings. When the screen turns off to reboot, remove the USB stick from the car.
When your screen returns, you'll have your JBL audio as well as the steering wheel's button for audio source working again. Having set Maps DRM to 0, now allows you to install the maps and map warnings as per instructions in this thread. You can leave this setting as it is as well (no need to change it back to 1).
For reference, I found what each of the Audio Mode values represents:
0 = Normal (internal amplifier)
1 = Hi-Fi (external analogue amplifier)
2 = Hi-Fi CAN (external digital amplifier)
3 = Arkamys (internal amplifier with Arkamys DSP audio)
4 = Arkamys + Hi-Fi (external analogue amplifier with Arkamys DSP audio)
I tried 3 (the default set when I fixed my RT6) and 1. Neither worked with my JBL addon. 2 is the correct setting it seems.
Hopefully the above helps someone.
Hi, just wanted to say a big thank you. i know its an old post, but managed to fix my rt6 in my 3008 using your process.
Everything works as it should, the stalk controls didnt but a quick play with activate deactivate, sorted that.
I just need to install Navigation now.
JWH
Northants
Hi
I'm after a bit of help after having my SD card fail in my RT6.
I have managed to replace the SD card, load the 8.26 firmwear, and load the maps.
I had the no sound issue with the JBL system and no Language option, but have managed to fix those with mirascripts.
I seem to have 4 issues left, no pop ups such as door open on the display, no navigation data on the instruments, the bluetooth echo and finally when pairing to the car it identifies as a citroen.
I have asked Mira and he has suggested getting a configuration file from another RCZ and trying that, would someone be able to help?
zuberismail
uk
Hi
Do you have a copy of the files that were on the old SD card?
