Akif3008
Bosna i Hercegovina
The previous guide is a little bit old so I decided to update it with the latest possible FW, latest maps, and updated risk areas.
LATEST FIRMWARE: N42c (final update - SatNav support discontinued after 2016).
LATEST MAPS: EUROPE 2025-1 (For Eastern Europe (maps 2020-2) use this
LINK)
LATEST RISK AREAS/RADARS: EU RADARS 2024.10 (OCTOBER 2024 Update)
All files are available in their respective parts of the guide.
UPDATING THE FIRMWARE
1. Check your installed firmware version via SETUP -> Settings -> Version Information
2. If you see N42c anywhere in the presented firmware version you already have the latest firmware and you do not need to update it. You can move to the MAP updating part of the guide. If you do not have the latest version, proceed to step 3.
3. Download this file: LINK
4. Prepare USB 32GB or SD CARD formatted as FAT32, 64KB Cluster size.
IT IS IMPORTANT THAT YOU FORMAT VIA WINDOWS AND DO NOT USE QUICK FORMAT. The regular format will take more time, but it is absolutely necessary.
5. Extract the downloaded file and put all files into the ROOT of the USB/SD CARD. Enable in Windows to view "hidden files" and check if any file other than that of the firmware generated in the root of the USB / SD CARD. If you see any "rogue" files, delete them.
6. Turn on the car. Keep it running and insert the USB or SD CARD into their locations (SD CARD in front of the Console, USB under the armrest).
7. If you followed the guide the NG4 system will automatically detect and prompt you to start the update. Click yes on the console and wait for it to finish.
KEEP THE CAR RUNNING UNTIL IN FINISHES WITH THE UPDATE. You do not want the car to turn off and cancel the update. It could destroy your system.
8. When the NG4 resets check the firmware version again. If you see N42c the update was successful.
UPDATING THE MAPS
1. Download this file: LINK (2024-2 with original 2016 POI from PSA).
2. Prepare USB 32GB or SD CARD formatted as FAT32, 64KB Cluster size.
3. Extract all files from the ZIP file to the ROOT of the USB / SD CARD. Enable in Windows to view "hidden files" and check if any file other than that of the map files included in the ZIP file generated in the root of the USB / SD CARD. If you see any "rogue" files, delete them.
This is how your USB / SD Stick should look like after copying the files (everything should be the same, except the last file which is from the 2020 maps):
4. Turn on the car. Keep it running and insert the USB or SD CARD into their locations (SD CARD in front of the Console, USB under the armrest).
5. If you did everything correctly, the NG4 will recognize the new maps automatically and prompt you to start the update. It takes around 40-50 minutes. It is advised to drive around with the car in the meantime.
KEEP THE CAR RUNNING UNTIL IT FINISHES WITH THE UPDATE. You do not want the car to turn off and cancel the update. It could destroy your system.
5.1. If during the update the error 0x26E appears, just press "OK" and wait for the system to restart (leave the key or SD card connected) and it will continue the update.
6. When it finishes, it will prompt you to press OK and remove the USB/SD CARD. Remove it and ONLY THEN press OK. After the NG4 System resets check the map version via SETUP -> When in the setup menu LONG PRESS SETUP -> GPS Information -> Map Versions. You should see "NG4 EUROPE 2023-Version-1.0".
UPDATING THE RISK AREAS
3. Extract all files from the ZIP file to the ROOT of the USB / SD CARD. Enable in Windows to view "hidden files" and check if any file other than that of the files included in the risk areas ZIP file generated in the root of the USB / SD CARD. If you see any "rogue" files, delete them.
4. Turn on the car and go to NAVIGATION -> SETTINGS -> IMPORT MY POINTS OF INTEREST
5. Select the Media you used (USB or SD CARD) and press YES to validate, that it will overwrite all previous risk areas.
6. After it finishes with the installation of risk areas (takes approx 10 seconds) a message appears to confirm a restart of the NG4 system and to remove the USB/SD CARD. Remove and press OK.
7. When the NG4 System restarts, all you have to do is to enable the risk areas/radars alerts in the Navigation menu. SETTINGS -> RISK AREA SETTINGS -> ENABLE all options.
8. You can check the latest risk areas/radars update in the same menu, that you used to check the MAP Version.
CAUTION. Proceed with every step at your own risk. It is extremely dangerous and it can destroy your NG4 system. No one on this forum or the forum itself is responsible for the caused damage and possible expenses.
I managed to install everything in one afternoon with no issues (my car is RCZ 2013 model). Take your time, follow the steps and it should be fine.
EDIT: Updated the link for the maps and updated the guide a bit - added a photo of how should USB / SD Card root directory look like after copying the files.
EDIT 2: Added the link for Eastern Europe maps - maps from 2020 (Courtesy of Ross_Russev)
EDIT #: Updated the links for MAPS and RISK AREAS - due to new updates.
which maps are the best for Bosnia, which maps have full cover of Bosnia? Thank you 🙂
Zardos
united Kindom
Well I took a risk and bought the download from eBay for £16 all working as it should again! All POI have reappeared so all sorted again now
Update, not all as well as it would seem, went to put in a post code the other day and it had reverted to the useless partial post code which the update on here had fixed so guess ill be trying this download again!
  • Like
Reactions: NF7
bybitmerchant
Malaga
Hello guys! Thank you for provided information. I have supdates my maps and risk areas with your links and instructions, althought I have Peugeot 3008 with Ng4. The only thing which I do not understand is that i can't start guide routance to any inputed address with the house number. I always get a error "Data input invalid". If I chose any address in the system i get the same error, do you have an idea what to do? Otherwise if I chose a place just on the map without address input, everything starts ok.
NF7
Slovenia
Yes, but you cannot navigate on street level. Any ideas ?
I have no idea what you mean. You are absolutely able to navigate on street level - I was in Brussels with the same version as is on the first page.
Steven65
Belgium
I can't type in an address, I can only indicate a point on the map when I choose Belgium as the country
Try searching for a street in another country...
Usually, if a street doesn't appear, it's because it doesn't exist on your NG4 maps with that exact name, sometimes because the article is missing, like "l'eglise" instead "eglise."
Kirk
Sheffield
I'm hoping someone can help me with a dilemma.
I have an issue with the screen software version on my Sat Nav unit. The Software version is saying "Invalid" and is causing an issue with telephone numbers ringing me not being displayed. I've updated the firmware version to the latest version and the maps and POI and was hoping one of these would fix it. Apparently they haven't and I'm stuck as what to do next.
Does anyone have any idea what I can try next.
RCZ-Fan
Deutschland
Hast Du Dein System mal auf "Werkseinstellung" zurück gesetzt und dann die Updates gemacht?
Sind es die Updates von dieser Webseite oder hast Du andere Updates Datein genutzt?
Kirk
Sheffield
I have used the firmware, maps and POI from this website, but did not tried a factory reset before installing them. Do you think the factory reset will add the missing screen software version. What version should I expect after doing this operation. I assume after doing the reset I will have to reinstall the maps and POI
NF7
Slovenia
Factory reset will not delete the maps. It will just delete the settings.
Kirk
Sheffield
Just tried a factory reset on the unit and you were correct. it did not loose the 2025 maps. Did expect the loss of music and links to my iPhone and will now reinstall these. Unfortunately, this reset did not fix the problem and the screen software version is still showing as invalid. Was a logical exercise to try but not sure what else can be done. Never having any CDs/DVDs when I bought the car from new, was there DVD which may have covered the Screen Software version.
NF7
Slovenia
I've never seen this happen. I'd just try to install the latest firmware again.
Kirk
Sheffield
Just tried reinstalling the firmware files and it has made no difference to the screen software version. It is still showing as invalid. However, "the plot thickens". (English phrase). Map locations are no longer showing full UK post codes. They are only showing the the first half of the postcode and the first number of the second half (example "S8 8XZ" is only selectable as "S8 8"). This is something which use to exist when I first got the car back in 2012. I will reload the Maps USB and hopefully this will fix this problem.
As to telephone numbers imported on to the unit from my iPhone, I do notice they are imported with blanks between country code, prefix and actual number (e.g. +44 0777 123456). Yet if you add a number manually to the address book of the NG4 you are not allowed to add spaces. ( i'm going to play with this and see if updating the address book manually to not have spaces will fix the problem.
Thank you for your assistance so far.
  • Like
Reactions: NF7
