Coolant Thermostat Housing
kdchrcz20
B757HP
Was told by garage that the above is leaking...How big ah job is this to change?
Thanks K
Its not too bad a job there are a few videos on YouTube for the mini equivalent a bit fiddly and there is a pipe that runs at the back of the engine that if dislodged is a pig to get back in.
JazzyRCZ
Thanks K
garage done it for me for 80 pound labour, i bought the part from ebay store, just make sure its the right one as the thp 200 and thp 156 versions are different
Its also worth noting that the seals in the banjo fitting on the Turbo coolant pipe from the block are another big suspect for leaks on the RCZs prince engine !
I would only buy the dealer part because from experience I know that some aftermarket parts will fail as they came without the electrical connection upgrades needed to wire them in especially on the 207 GT
