AC problem Is there a solution please
athir1972
drdino said:
Which codes exactly had the HVAC ECU stored?
Today I went to another diagnosis and the result was so here could be the problem in this picture
athir1972
the other test.
drdino
You are not going to get a/c working until you fix these. A/C pressure sensor is definitely needed for it to work. The thermostat is probably required as well.
athir1972
thank you. what about this picture what he meant ??
athir1972
I think the problem i the thermostat will be must Replace . If the problem is in thermostat Is it reasonable that this problem cause the air conditioner to stop ?? It's a very stupid system.
Quite possibly :eusa-think: I recently had the thermostat housing changed on the wife’s Mini CooperS (same engine) and now the air con is not working so there is definitely a link there.
drdino
A/C puts increased heat load on the engine and cooling system, therefore it might be the case that if the ECM thinks there's an issue with the thermostat, it doesn't allow the compressor to he switched on.
The pressure sensor is important as well.
athir1972
yes mate probability.
athir1972
Even if the car is cold and the morning starts up. The compressor does not work?!
Now I will change thermostat And see what will happen.
drdino
Dont forget the a/c pressure sensor, that's equally, if not more, important.
athir1972
I have been replaced the thermostat. Now AC cooling works well...I will sell this stupid car and go back to Japanese cars that are comfortable and just turn on the engine and work without a headache.Thanks to everyone who tried to help me
ONLY AEK
greece
yes you should
take a jap car that does not have a/c and it will never have a problem with the a/c
athir1972
ONLY AEK said:
yes you should
oh yeah my new Japanese car without A/C :police: I will move to Canada so I do not need it. :lol: .... cheers
