Windscreen and headlight washer pump
NeillyWheely
Glasgow
Hi guys,I'm hoping someone can be of assistance.My windscreen and headlight washer pump is now goosed and I'm assuming one pump operates both.Does anyone know where I would be able to buy one.Thanks,Neil.
Jacek Jackowiak
Po
Windscreen washer pump - fuse no. 3 under the bonnet.
The fuse for the headlight washer pump is in a less accessible location. It's easier to check if the OBD II port is working. If communication through the OBD II port works, it means that the fuse for the headlight washer pump is OK. The headlight washer pump and OBD II are located on one fuse.
NeillyWheely
Glasgow
Hi Jacek,located fuse no.3 under the bonnet and yes it had blown.I’ve changed the fuse and all good.Thanks for the heads up 😉
