Which Thermostat for 13 plate Thp 200 Model
Mikefranky
Wales
Look like I need new thermostat for above model am I right in thinking there’s different types and I need the one with the elbow part attached?
Any part numbers be of great help guys...I’ve just read you need a new wiring harness as well?
You'll need to replace the "Elbow" Tank on yours which houses the Thermostat sender but you need to order the exact part as I have the same model & it took them 2 attempts before they sent me the correct 1 as I didn't realise there can be different variants I got mine off ebay but you need the part no which are listed in numerous parts stores across the web as I can't remember offhand what it was sorry mate
Mikefranky
Wales
Cheers for reply......From what I’ve read I might have to Change the wiring as well as apparently they been upgraded with different plug for the sensor
I really do want go down main dealer route but there’s a Peugeot dealer just down the road from so if wrong part is ordered it’s easier to exchange......unlike parts off eBay etc
The 200GT is a straight swop over as the plug fits into the rear of the housing housing I believe the 156 & maybe the HDI had the wiring upgrade I think the put they sensor in the housing instead of having a bleed screw
Its not rocket science to change the housing it gets a bit fiddly around the back coupling the elbow into the coolant pipe but many on here have done it with success & saved money!
Mikefranky
Wales
Guess what I be doing bank holiday Sunday ...Cheers for the info
Will put up correct part no here once job is done to help out any you guys..
Mikefranky
Wales
Halfway through tackling this job just a quick pointer for any of you guys doing this job there seems to be a number of different thermo for Rcz if you have a mk2 200THP then look at the photos that’s the thermostat you’ll need with round connection type on the one side unlike majority of others with 2 think they are the newer version..
Part no-FTK486 1336cc....Lucky for me I have a good friend who’s tackling the job......I hate stress!!
£65.45
Mines on a 13 plate but still do your own checks.
I managed to track down my order No for 2013 200GT
Q H 1336CCV7645581809808647080 I presume it is a Quinton Hazel variant there's a guy on ebay sells a LOT of these tanks :rolleyes:😄
