When the engine is cold
More for reference really as I’ve got the guts of the cooling system out I noticed the thermostat housing has two arrows which I’m presuming is one to the top hose of the radiator and other for the inlet to the heater matrix but where does the water pump send it first? Is it the rear metal coolant pipe behind the engine (which goes to the thermostat housing) or through the main block jacket (which also goes to the thermostat housing)
I’m thinking to the rear metal coolant pipe first so the water pump is pulling away the heated up coolant from the hottest place?
