shoshin
Hi. The connector to my VVT solenoid reads just 3.17 volts with ignition on. This is far too low to activate it, but I'm wondering if this is normal at ignition and higher voltage is only supplied when it is required. Could anyone confirm please? Reason I'm asking is that having removed the old part it passes all the electrical tests just as well as its replacement, even though I was convinced that I had finally narrowed down my problem (the old P0016) to the VVT. Many thanks Martin.
