So, after owning my Z for almost 2 years, I have just discovered how to get the TPMS to check the tyres & the car to do a diagnostic check.
On the instrument panel above the steering column, there are two buttons in between the speedo & rev counter, below the small LED display. One on the right says check/000. If you press this, after a second or so the small led display shows the tyre pressures on the car (well, if they OK or not anyway).
After this, the large led flip up display goes through a diagnostic check of several things including automatic lights, automatic wipers, and end with a diagnostic conclusion.
I did check my pressures, and one front was 4lbs down, the other front 2lbs down & both rears @ 1lb down. So this system is OK for a serious pressure loss, but not for day to day pressure monitoring. This needs to be done manually.
