Hi deejayem and everyone else.
I am beside myself today as I have learnt that my RCZ is going to cost me $3564 due to the clutch collapse. The car is a little over a year old, I have had it for nearly four months, the previous owner from my understanding did not drive it hard, he had baby capsules in the back seats. I certainly do not drive it to hard and am insulted with this bill.
I am at a total loss as they first stated that it was under warranty and now they are saying it is driver abuse. Below is the email I received this afternoon.
Dear Kevin
I have an update for you on the clutch concern with your RCZ and it’s not good.
Can you please refer to the photo’s attached and review the damage inflicted on the clutch assembly.
We started removing the gearbox on Friday afternoon and finished removing it on Saturday so we could complete the repair by Monday afternoon, we inspected the clutch assembly and associated parts and found the clutch had been ripped apart due to driver / operator abuse.
The clutch plate friction plate has been ripped away from the clutch centre plate rivets and completely fallen apart, this can only happen by dropping the clutch at high RPM under extreme pressure.
The result is a disintegrated clutch plate, a damaged pressure plate, flywheel and a collapsed clutch hydraulic system, the pressure plate and flywheel have been overheated and this can be seen with the blackened friction surfaces.
Due to this evidence the clutch replacement and repair can no longer be considered a repair covered under the manufactures warranty, the full cost of the repair is now the owners responsibility.
Cost to repair is as follows:
1. Clutch dual mass flywheel = $1250.00
2. Clutch kit (clutch plate, pressure plate) = $585.00
3. Clutch fluid = $11.30
4. Clutch master cylinder = $154.00
5. Clutch slave cylinder = $126.50
6. Flywheel bolts = $15.00
7. Gearbox oil = $66.00
8. Labour to replace the complete clutch assembly and listed components = $1315.60
9. Total cost for repair = $3523.40
The clutch / engine flywheel is nil stock in Australia and will need to come from France, once we get your approval to proceed it will take 10 – 12 working days before it arrives, the car is in a state of dismantle as we wait on your reply.
Please note there was no way we could foresee this until the gearbox was removed and we based our diagnosis on the failed hydraulic system, unfortunately the hydraulic system failed due to the above explanation.
Regards
I had the same issue as you deejayem as far as the car having difficulties changing gear, pedal loss and then just failing altogether. The car has done 23000 KM's and I find it strange that I have never had this damage with any of my other manual cars, MX5, Calibra 4wd turbo, these were both manual cars. Any help or advice would be truely welcomed, I need to get this sorted ASAP however I don't feel as though I should be forking out over $3000.
Thanks and all the best, Kevin
