Third break light
If you do a search, there have been threads on that very subject 👍
It very easy remove the grommets take out the two t screws and the cover will come off, there is two 8 or 10 mm nuts to remove (one is tucked back a bit and if you get 5mm hex key to manually lift the fin or you can put the fin up before you start and the light will come out slowly... Be careful don't be heavy handed..... Fit in the reverse order... Good luck... Hope this helps you if not check out further on the forum before you get started...
Hi any tips for removing boot liner to remove third break light
Thanx
Remove all plastic studs by levering out the internal to release the stud if I remember I think there are about 16 then remove the two torx screws hidden in the hand pulls see photos remove the two nuts for the light fitting these are the outer ones disconnect light connection, there are two spring clips holding the fitting in from the top just wriggle the light unit back and forward to release then after cleaning all the dirt that has accumulated under the old light fitting replace in reverse order making sure the spring clips click home.6B631364-CC6B-4F4C-AA35-6CA77810EE04.jpeg035E6339-6B04-452C-A059-6BC6128601F1.jpeg6B631364-CC6B-4F4C-AA35-6CA77810EE04.jpeg2EB3693B-384F-41EF-BA26-E7BA3FE45101.jpeg2EB3693B-384F-41EF-BA26-E7BA3FE45101.jpegBE1936B0-0C89-4CE7-A24C-42C97195A7DC.jpeg8E431C73-11BA-425C-BB24-5ADDE20EC335.jpegE299AE1F-0F5E-46C8-9E77-71EE75D59863.jpegA42B7C57-9DA7-4B91-B884-3B429B715FA7.jpeg7C2CA6C1-E8EA-43AB-8FEB-D330CEF3C6CB.jpeg66857599-D54C-41FA-AD1A-3B2877D41791.jpeg
