steering judder at 70mph
What year & variant is your Z?
I had the front suspension top mounts replaced FOC as a notice from Peugeot. Not sure if this could have any impact on your judder, but if you have tried everything as far as the tyres & wheels go, the only way to go from there’s would be joints & suspension.
You could try lifting each front corner, and holding the wheel at each side, see if there is any play (can you move it) if so, it might be a cv joint or something along that line that has worked loose, or just worn, and is causing vibration at certain speeds.
