I changed the waterpump, tensioner and the belt (waterpump, ac, powersteering) in the summer. It was great.
Then after a month, the steering wheel started to vibrate when at low RPM. First gear and reverse are problematic. I can feel extensive vibration turning the wheel at 1-2k RPM. If I raise the RPM, the vibration goes away. It happens when the engine is cold and when it is at working temperature. I did not brush the curb or anything else, the road leading up to my house has speed bumps, but that should not be the culprit.
The vibration got even worse when fitting the winter tyres. I checked the tension of the belt (was fine), I checked the level of the oil of the power steering, it was fine.
Did anyone else run into the same issue? Is my power steering pump on the way out? Or is it maybe something different?
