Hi,
Has anyone else had a problem with squeaky brakes. Over the last week (with about 1000miles on the odometer) it started. If I press gently on the brake pedal the squeaking is quite loud. I took it in for it's 1000mile checkup today and was told it that they used some sort of spray cleaner on the brakes and that most of the time that would cure the problem, otherwise it would be a complete brake strip down. Unfortunately within 10mintues the noise was back.
This is on the 200THP with the 340mm discs at the front.
Cheers,
Jas
Cheers,
Jas
