Yo folks , sup ?
As the title says , got today the engine fault advise on screen.
NO engine light.
Car is going PERFECTLY , not a single issue , no power cuts / no high temps / no fan activations .
The warning pop off just 4/5 seconds after the car is on.
If i turn off the car , and then turn the key in standby mode , NO ERRORS in the car's history menu.
Car's already checked via OBD by a pro software , NO CODES ERRORS reported ,
even with multiple software reading refreshes with car on and the /!\ sign up on the main display.
I've left the car out my box for 2 nights with cold a humid weather,
plus in these 2 last months i used the car rarely , only for some weekend.
I'm starting to think that is something about battery capacity going down cause low usage/weather
and i've already readed on the net that can cause that kind of strange errors with no codes.
I repeat , car goes flawlessy as always , new oil , new NGK coils , sparks not yet changed ( 10k km's atm , still have new ones ready ).
Something to suggest that can help ?
Thank you indeed
NO engine light.
Thank you indeed
