almasviana
Pretty straightforward, out of nowhere the running day-lights stopped working when in automatic lighting.
I'm running LEDs (the old ones were going bad but they were also LED) and I remember the old ones working.
The new ones did function as supposed to when I installed them. THEY DO WORK when I put in the manual, and they light up in an automatic when the car lights everything up, only the RDL function is not working. I checked the car cockpit menu and turned on and off the RDL function, it doesn't work. I have heard that could be resolved with a BSI reset but I don't know how to do it.
The other problem is when I lock the car, the 2-second light signal doesn't light up right away, only after 45 seconds (I tried multiple times). It's annoying because when it's dark, I have to see if the side mirrors are closed.
I have a lot of other problems in my car that I want to fix, and I'm pissed off being scammed by mechanics. Over 1200€ and the same problems are popping up (max turbo pressure related), I will make other posts about it and I'm looking for some help if possible!
