Power steering on 2010 RCZ
th3g3rmb0y
Ulleskelf
Morning all,
I believe I may have an issue with my power steering. On turning (either direction) at low revs, there is a lot of shudder and feedback through the steering wheel. I took the car into Peugeot and they quoted nearly £1000 to replace the power steering.
Can anyone advise if it's easier/cheaper to get a replacement power steering unit second hand and have that fitted?
Is it a possible DIY job?
Thanks in advance.
Dermott
th3g3rmb0y
Ulleskelf
Oh. I did not know that. Do you have a link to what the module is / where I can get a replacement?
I'm assuming the module will be a plug in/out item, so should be easy enough to replace?
I dug this out but I'm overly busy at present so when I get the time I will try & search for more data
GOODALE
I would be interested to know about this guys as my HDI 2.0 RCZ is a 2010 model and I find the steering quite hard compared to the Kia Proceed GT I had, wondering if all RCZ’s are hard on the steering or do you think the steering might be a module as well
wilsofar
Redditch,Worcestershire
Having had a Mark 1 156,and a Mark 2 200, yes the steering at low speeds is quite a lot stiffer than many recent models,such as Peugeot 2008,VW Up!(don‘t you hate the apostrophe!)
However all is forgiven once properly on the move when everything comes to life (light)!
