Pcv delete on THP 200?.
Re:UPDATE!!.., Pcv delete on THP 200?.
UPDATE!!....after getting my head rebuild 3 month ago the exact same problem has returned.Im really in 2 minds to go back to the garage I used as I wouldn't rate the service I got so thinking about getting over this problem myself so I know they can't rip me off again...(but that's a different story).Anyway hear we go again,...car drive perfect until I push it hard and it does pull hard till maby 4/5/6 gear and 5k rpm on the over boost and it starts to hesitate and stutter then shuts down into safe mode with 'engine fault' on dash.If I stop and switch the car off and start again it will be perfect again until I push it up throu the gears and 'BEEP' ...same again.There is no code on the ecu.i pulled the turbo pipe off and noticed a small trace of oil in the intake pipe going into the turbo,is this normal coming from the rocker breather?.It does feel like slight detonation on high boost,is there anyone out there with and idea or info on this matter??.
I'm seriously thinking on taking the engine out and starting from scratch so I know what I've got but performance things still seem abit scarce for this motor.
I just don't think there has been that much interest by many in performance modifications on this car and so there hasn't been that much development. However, I would expect this to change if the demand is seen to be there.
