Passenger Seat not responding. SORT OF SOLVED!
Nova
Sweden
Hello!
I recently bought a 2010 Peugeot RCZ 1.6THP 200hp and the passenger seat is high up and non responsive to changes.
I have tried switching out the fuses for the passenger seat controller, I have cleaned the controller board and switched out the Relays.
One of the relays got warm (not hot), and one had no heat gain, so clearly the chair is getting electricity otherwise the relay wouldn't get warm right?
Any ideas what else could be the issue?
I believe Drivers side is memory position function not sure if the passenger is also although apparently issues arose relating to Battery spikes causing seat malfunctions ?
Might be software issues I'm not sure if their ECU-BCM controlled
Nova
Sweden
So as it turns out... A 5A fuse to the lights, was making the seat for whatever magical reason unable to move 🤔 Occasionally the fuse will burn out so some underlying issue cause it, but switching out that 5A fuse made the seat work again!
Great news wonder if you have a ground fault or open circuit somewhere maybe check if it goes again?
