thornebt
- Joined
- Feb 23, 2014
- Messages
- 234
- Reaction score
- 9
- Points
- 18
I got the P1340 error code on my OBDII fault code reader last week after engine misfiring. I looked the code up and it said it was a severe misfire on cylinder 4. I changed the coil pack and all seemed fine until I got the same error code and misfire today. I then found a different description for the error code:
P1340 Camshaft position sensor B circuit Malfunction
Whilst looking for connections to the camshaft postion sensor I noticed that the plastic multi connection block that I'm pointing to in the photo was incorrectly fitted above the metal bracket that's supposed to hold it in place. Subsequently this part was being forced higher than it should be. I managed to fit it correctly and my fault code has now cleared.
This connector block has a long plastic casing that goes down alongside the engine. Can anyone please tell me if this part is something to do with the camshaft position sensor? Perhaps it's wrong fitting produced the fault.
The part must have been fitted incorrectly by Peugeot some time ago as they did the timing chain, tensioner etc under warranty. It's a bit disappointing when the main dealer can't get it back together correctly!
Cheers. Bruce.
Cheers. Bruce.
