Hi everyone! Does anybody know how to open the trunk from inside the car?
Cheers!
Cheers!
xmark said:Hi everyone! Does anybody know how to open the trunk from inside the car?
Cheers!
frankvdb said:Regarding the boot, I'm pretty sure the middle key button also works with key in ignition and car running.
RCZ1 said:frankvdb said:Regarding the boot, I'm pretty sure the middle key button also works with key in ignition and car running.
I've not been brave enough to try that in case it caused a problem with the electronics/immobiliser or something. :eusa-think:
johnw said:I can't see it causing an issue with electrics - peugeot would be very silly if they let it do that. I would say it is unlikely to work though - you would think they would prevent it from working as there could be a possibility of the boot being opened whilst driving - lets say for example that your passenger has the spare key and presses the button - if the motor is running it should not let the boot open. I don't know how other cars function but I suspect that it is the same - no working boot button all the time the engine is running.
Snowy87 said:While on the subject, is there any facility (pull cord etc) to open the boot in the event of a power failure :?:
stevebasshead said:As luck would have it I just tried this before reading the latest posts here and I can confirm with the engine running the middle remote button won't open the boot. Once the engine is off the middle button is re-enabled and the boot opens.
Sent from my GT-N7000 using Tapatalk 2
