kermitfrog123
Good morning all,
My car is a 2010 Peugeot 308 GT with the THP200 engine and has done a little over 100k miles. Not so common in a 308 I believe but is common in the RCZ hence posting here. I have read hundreds of posts and tried numerous different things. I am not 100% DIY friendly, but my car has been with a local independent a few times and I am still having issues.
So, at the moment my symptoms are as below:
I know the car is old and high mileage but I love it. It is pristine inside and out and just has these gremlins. I would love to get this resolved but am lost at where to start. The independent garage basically gave up and gave me the car back. I am happy to spend the money to fix the car but would rather my money wasnt spent trying things on a "maybe this is the problem" attitude.
My opinion (not qualified in anyway) is that because the car drives perfectly when these errors are not present it must not be a mechanical problem and more of a sensor issue.
Any help anyone can offer would be much appreciated.
Many thanks
Joe
- Only When Cold I will get an error on the dash "Anti-Pollution System Faulty" and an engine management light. I have a cheap code reader which reads a variation of the below not always the same. If I clear the code it will disappear and will drive perfectly afterwards.
- P0012 - A Camshaft Position Timing Over - Retarded Bank 1
- P000A - A Camshaft Position Slow Response Bank 1
- Anytime Hot or Cold if driving and hovering around 3500rpm I can see "Engine Management System Faulty" on the dash with no Engine Management Light and no codes stored. This error means that when driving I feel like I have no turbo (not limp mode but certainly no turbo mode). If I stop the car and turn off and on again this error goes away and the car drives perfectly again.
- Timing Chain and Tensioner replaced
- Turbo Diverter Valve
- All Vacuum Pipes
- Oil and Filter Change. 0w30 Castrol Oil
- NGK Spark Plugs
- Rocker Cover replaced
- VVT Solenoid replaced
Many thanks
Joe
