Hi guy's. I have done this now. It took me about three hours altogether. I was moving at a snails pace to not make any mistakes so it could be done much quicker by someone more competent. I am not sure what they charged in the garage for this but it cost me all in all £66.00 (New rocker cover + gasket) £3.00 Break Cleaner to clean where gasket seals) I probably did not need the new cover so it could be done for about £20 if you replace the gasket only. It is not overly hard just make sure you have access to a torque wrench that goes to 10nm, and screw drivers for jubilee clips etc. it seems to be staying clean on top and was running perfectly once done no EML ETC. I did notices a small oil leak after not sure if this is another issue or the last of the oil seeping off the engine from the old rocker cover. I will keep you guys updated. I do have two quick questions regarding the last two pics for this in the know.
1. Should this pipe have a jubilee clip on it? It is going into the top of the engine on the right hand side.
2. What is the red thing that came with the rocker cover for?
Thank you for all the help much appreciated.
Bob
