oil leaking on top of cover
devyalfa
kuwait
hi everyone ,,yesterday i noticed that there is oil leak around the coils on the top of the plastic cover not sure if the oil came fron coil or sparks plugs since i have no issue with the car and run smoothy and no warning light but i would know what caused of that oil between coils on the cover .
I can't see it coming form the plugs or coil packs as they are sealed once fitted it may be the rocker cover or possibly oil mist form the breather pipe? Check the hoses for any splits the rocker cover gaskets are on some cars a leak issue but usually only if they have been removed at some stage & not refitted properly
Mines exactly the same very common I’ve no issues with mine I’ve had the rocker gasket done but it still weeps new cover is only solution.
Woodso
Huxley
Yup, same with mine. Oil on top of the rocker cover and weep on O/S join to engine. I just live with it and clean off with a wipe when I do the rest of the engine bay once a week.
