Your loosing boost, or not creating it. is there and whooshing noise on ‘fun’ revs?
Boost lose checks.
start down at the throttle body and check to see that it itself is seated flush, there is a spud to help alignment when fitting.
Then the 90deg that comes off it heading up the back of the engine (jubilee clip / 7mm socket) as you can see it it’s very easy to misalign.
keep following up looking for misaligned pipe as it comes towards the intercooler and the two red pipes, checking for cracks too.
Check the intercooler, a damp dark patch is a tell tale.
That brings you up to the cold side of the turbo and if all okay then take a look at the Pierburg pressure relief valve mounted on the rhs of the turbo, three Allen keys remove it and inspect the orange diaphragm for any signs of splits.
Vacuum checks
Is the vacuum pump working? Do the brakes feel okay or is there any pulsing feel?
Check your vacuum lines, comes of the top of the vacuum pump, is it still well sealed, follow it, there is a vacuum solenoid clipped on to the inlet manifold (if loose it can fracture the plastic pipes over a short time). Is it plugged in correctly electrically too. From the solenoid it heads to the turbo and becomes a rubber pipe where it goes onto the wastegate solenoid, check it’s a tight fit with no cracks (peel the mesh back an inch or so to see it. There also is a branch of the vac line that goes to the brake boost, check it.
A smoke machine would be really good to have for the above checks, save a lot of time.
If all okay so far the wastegate on the turbo might not be closing correctly, the hinge on the wastegate wears and then it doesn’t close fully or the wastegate vacuum can may be faulty or stuck. I list out the turbo focused stuff if you want later.
The fan issue is a bad connection or bad fan resistor, if your scan tool is bidirectional go into it and test the two speed to see what it gives you. Check the wiring to and fro.
Boost lose checks.
Vacuum checks
