My Peugeot Rcz won’t start help please needed ☹️
Angi
England
Hi can anybody advise me please .
i got in my car this morning would not start at all ,! petrol is in . It turns over but it does not even sound like it’s trying to start .
could it be either immobiliser on or possibly crank sensor
awaiting advice tia
angie
Marmite
Maybe hpfp or lpfp located in the tank I would check this first then is there a spark at the plugs an get a Obd reader to see if there any faults stored
This issue could be down to a number of things but it can point to low Battery-power control module/ fuel /ignition or as you say the immobiliser or even the battery in the key fob is failing try changing the key battery see what happens
Failing that it may be BSI reset as the alarm/ immobiliser & ancillaries are run off that system
Angi
England
Thank you I will let you know outcome when I’ve got the finances just had to park it up for moment 🤨🤨
Angi
England
Thank you for your help will let u know outcome finance pending ,just parked up at moment🤨
