Multi Point Check issues
pfaulkner
Crewe
Peugeot Gateway in Crewe have done the multi point check and have said that there is an oil leak coming from the solenoid wiring and to rectify the issue it will cost £600 as they need to remove the drive train to access it...Does this seem right?
Also the cambelt is cracked and there is a leak from the rocket cover gasket - do these need addressing asap?
Well as I am sure that you know peugeot dealership change you the earth. But like any other garage it's finding one that is good and you can trust, worth shopping around and making a few phone calls.
Hope you get sorted out..
JC1
Can I ask what they charged for the window regulator? Im just about to do mine, failed at 44k miles..!
pfaulkner
Crewe
Peugeot Gateway in Crewe charged me £800 for the regulator, motor and labour. They also replaced the door lining, screws and wiring due to a botched attempt by the previous owner.
RIP OFF! But nobody else would/could do it and the window was all the way down at a time when it was raining for a few days.
JC1
Oof that's a sore one mate! I got the regulator for £230 still sore at that.
Quite a few RCZ’s in our local breakers sounds like something they would have
Sounds expensive, unless you trust this dealer impeccably then I would be suspicious any multi point checks. If you have a petrol they don’t have cam belt it’s a chain. A leak from the rocker cover is common and a pain to sort I’ve had two gaskets and it’s still weeping.
pfaulkner
Crewe
Sorry Aux belt not cam belt.
JC1
I found a 2nd hand unit on Fleebay, they wanted £189!!! Unreal
Thing is as time goes on prices for parts are going to go up and up, but it’s worth remembering that some parts are shared by 308 and some Citroen’s.
I think if you're thinking about keeping your RCZ for many years then it might be worth getting a few spare parts in your garage for when things go wrong and at the moment the price is right as previously stated they will go up and you can not lose out if you don't use them some one will need them and as you know that the price is lower now as they will be in the future so a am sure you will not lose out I have now a small stock pile of items that may go wrong and I will need in the future I keep going to the local scrap yard and buy them for the sake of buying lol 😂 might have to buy one of them on ebay for next to nothing parts worth more than the price of the car might need a bigger garage lol 😂
All drive safe and stay lucky 🍀
