hi had small oil leak been in was rocker gasket cover. supposed to be. replaced drove to work. engine come back on now said low oil pressure. when i started it up was taking a while for temp gauge to move up. any ideas guys. saying engine pressure two low. the gauge eventually goes up but taking it time as then warning kicks in.
Could be a low Oil pressure sensor issue has triggered low oil warnings in the ECU sending the EML on the dash & as the outside air temp is getting colder (Winter) it will take longer for the engine temp to get up to normal as the cars has a outside Atmospheric sensor & electronically controlled water pump
