Hi All,
Was wondering if you might be able to help me here. Car has the deeaded engine light come on intermittently causing it to judder and lose power at times. However at other times it runs relatively smoothly with no issues and the light disappears.
I've scanned the car with Peugeot plannet and got the following back:
Intermittent fault. Injextors control 4 short circuit to positive
Intermittent faul. Petrol high pressure regulation fault Fuel rail pressure too low
Intermitten fault. Misfire on cylinder 2
Intermitten fault. Misfire on cylinder 3
Intermitten fault. Misfire on cylinder 4
Intermitten fault. Misfire on undertermined cylinders
Remote intermittent fault. Mis fire detected dfuring low fuel level
Intermittent fault. Oil pressure regulation Pressure too high in relation to the setting
Does any one have any ideas what the issue(s) might be. I have tried to browse through the forums, and was thinking potentially coil packs and spark plugs ( or at least praying). My other thought is that it could be the HPFP. I'm praying it is not the timing chain, or other more serious engine related issues. Any help would be greatly appreciated!!!
