I’ve searched and searched the web but cannot seem to find anything on the internal boot courtesy lights (one upper one right) which both appear to not be working on my recently purchased 2010.
I’ve removed both lights and replaced both bulbs (twice) checked any relevant and some irrelevant fuses (thrice) and can’t seem to find the problem with it.
All other courtesy lights in the car are functioning and all visible connections seem fine so was just wondering if there was anything else I should check/ if anyone else has had this issue ?
As I can’t find any info at all anywhere and didn’t want to miss something obvious before I pull out the entire boot and chase all the wires :/
Thank you!
Thank you!
